9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible), 158 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#519338 03/21/2009 4:06 AM
Hey guys!
I used the forum search function and I see this is quite the discussed topic. I couldn't really get my question answered so I thought I would post it.
On a 41 chevy 1/2 ton where does the horn wire exit the steering column to go to the horn.
Anyone have a picture?
Thanks for the help!
Ex Hall Monitor
Ex Hall Monitor
If it's like my 38 there will be a hole (1/4" or 5/16" never measured it) on the bottom of the steering column a few inches above the steering box. That is where the wire exits on mine.
Tiny #520071 03/23/2009 4:14 PM
Tiny is right. Just make sure you stick a rubber grommet in the hole to prevent the wire from getting warn, causing a short.
George
