| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | Ok so I am flipping through 60-66 factory assembly manual and I come across a page that lists a steering pump bracket for the L6 (3894004) It's like on the last few pages. Has anyone ever seen this bracket or know where it is sold? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | well if your truck is a 63 and up it will be either a 230-250 or a 292. they were made for quite a few years so check around for something newer with those engs in it wiith power str). passenger cars to). just make sure of same length waterpump so that the belts line up. you won't find to many around for that vintage as manual strg was quite predominate ron
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i think the later model brackets work with a double fan pully. the rest of the set up is different unless you are adding on the other steering componants from a later model truck. have you ever seen these factory ones from the early 60's pretty cool. | | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | Thanks for that tip! I will be hunting around for one of those. No I have never seen one from the early 60s, picture anyone? lol | | |
