2 members (BC59, Gray_Ghost),
154
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,079 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Ok, when puttin a new/used voltage reg in, I gottuh polarize it. What is it again, field tah Batt, or what? Also tah pull the brass sleve ottah the back of the generator, how do you do that?
TIA and Adios, Kip
Write On The Cross At The Head Of My Grave To Whiskey And Women Here Lies A Poor Slave
| | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Hey Thanks 2M2C, the only thing is I don't have a "D" terminal. I just got "Bat", "Gen" and another one I don't remember what it is but it ain't "D".
How do I get that brass race sleeve outtah the back of the generator?
TIA and Adios, Kip
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Hey Thanks Tim!
Any ideas how tah get that brass bushing out, anybody?
TIA, Kip
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you want to save it, pack it full of grease, find a wooden dowel a size to fit in the hole snug and smack the dowel - the grease should force the bushing loose, like doing the trans pilot bushing in a flywheel .... if it's gonna be replaced it should work to cut threads into it with a bolt the right size and turn until it comes loose
Bill | | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Thanks Squeeze! I'll try the dowel thing.
Adios, Kip
| | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Yeah hey, tried the dowel deal, no go.
I broke down and took the Dremel to it.
Thanks Guys!
Adios, Kip
