0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
Kip
Offline
Ok, when puttin a new/used voltage reg in, I gottuh polarize it. What is it again, field tah Batt, or what? Also tah pull the brass sleve ottah the back of the generator, how do you do that?
TIA and Adios, Kip
Write On The Cross At The Head Of My Grave
To Whiskey And Women Here Lies A Poor Slave
Kip
Offline
Hey Thanks 2M2C, the only thing is I don't have a "D" terminal. I just got "Bat", "Gen" and another one I don't remember what it is but it ain't "D".
How do I get that brass race sleeve outtah the back of the generator?
TIA and Adios, Kip
Kip
Offline
Hey Thanks Tim!
Any ideas how tah get that brass bushing out, anybody?
TIA, Kip
if you want to save it, pack it full of grease, find a wooden dowel a size to fit in the hole snug and smack the dowel - the grease should force the bushing loose, like doing the trans pilot bushing in a flywheel .... if it's gonna be replaced it should work to cut threads into it with a bolt the right size and turn until it comes loose
Kip
Offline
Thanks Squeeze! I'll try the dowel thing.
Adios, Kip
Kip
Offline
Yeah hey, tried the dowel deal, no go.
I broke down and took the Dremel to it.
Thanks Guys!
Adios, Kip
