5 members (Guitplayer, Steelonsteel, greenie-reddy, Maybellene, 1 invisible), 133 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
I bought new lines from Jim Carter and they were supplied with(2) right angle brass fittings. The rubber lines thread into this fitting and this fitting threads into the filter housing.
I contacted Carter and their response was they don't have any. I don't mind buying them myself but I don't know how to properly identify them. Can anyone help me out with what these are called?
Keith
Keith,
You state you were supplied with the fittings by JC - did you mean "were not supplied"?
Here is the Weatherhead-Eaton brass fittings catalog. These part numbers work at NAPA. They even have the T-fitting for the block (for the oil pressure line and oil filter line).
Tim
The threads in the filter housing are most likely 1/8 inch female pipe. The rubber lines will probably have 1/4" flare nuts on both ends. You would need a 90 degree elbow with a 1/8" male pipe thread on one side, and a 1/4" male flare thread on the other side. Any good FLAPS should be able to supply those fittings.
Thanks guys-
Tim I did receive the fittings from JC..There a good outfit this is my bad..I either misplaced one or mangled it somehow last lear and tossed it-
Thanks Lincoln...
Looking at the catalog and see on that looks good.
Keith
