Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
9 members (DoubleB, Hotrod Lincoln, Tiny, Rosco, smeyer6, SNOYL, frogfarmer, ShopRag, Dakota Bob), 143 guests, and 1 robot.
Topics128,292
Posts1,058,590
Members48,492
What are you guys' thoughts on what the best rear end ratios are for all-around driving for a swap from a 3:90 torque-tube to GM 10 bolt on a 1954 Chevy 235 half-ton?
I have a choice of an original GM10 bolt ratio of 3:08 or another with 3:41 and yet another with 3:73 gears! What would be the best balance for all-around driving highway, occasional light hauling and around town....?
Depends on the tranny. Are you gonna go with a Overdrive T5 5 speed or keep the 3 or 4 speed? If your going w/ 5 speed, the 3.73 will be best. IF your gonna go w/ 3 or 4 speed I'd use the 3.42. Just MY2¢
Riding in the Passing Lane
I agree. 3.41 is about right without o-drive & 28- 29 inch diameter tires.
1972 Chevy c10 Cheyenne Super
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
Try thinking of it this way: in 55' the standard shift cars came with 3:70 ratio. OD 3sp trannys were 4:11. And that was a car equiped with either the 123HP 6 cylinder or the fancy new 162HP V8. In 57' the standard rear became a 3:55 for a car w/o OD. The tire diameters were smaller then too than what most of us use today.
This was all figured out by qualified folks who did their homework. (on sliderules) I still use mine occasionally.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks all but now I'm more confused than I was before! wink
I think I'll do the 3:41 (3:42) Anyways I'll avoid the sliderule and pocket calculator for now....
BTW the truck is gonna have a '56 Muncie 3 speed set up for the original three-on-the-tree. That'll match the '56 235 under the hood which replaced a '42 216 some misguided soul put in to replace the original 54 235. A lot of bad happens in 50 years.
If anyone is interested I will soon have available a completely rebuilt 54 Muncie 3 speed (with brand new speedo drive gears, really hard to find!) brand new torque tube U-joint assembly including ball housing and a very good running torque tube rear end with a new Okie bushing, comepletely serviced brakes and new axle seals. My loss is your gain.
