| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51858 11/03/2005 6:30 PM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | I'm done with my tranny rebuild and only about a good hour or two away from finishing my 228 rebuild for my '40 GMC.
My questions are: 1) Does the tranny get hot enough that it needs high temp paint? 2) Are the engine, tranny and flywheel housing all supposed to be painted the same color or does it matter? 3) What parts on the engine are supposed to be black (i.e. starter, generator)?
I went ahead and painted the tranny semi-gloss black, but it's not high temp. I can redo it easily now if I need to. The 228 will definitely be getting the factory olive green high temp treatment.
Thanks for any input.
Neil 1940 GMC 1/2 Ton
#51859 11/03/2005 7:46 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | AFAIK the transmissions were not painted at all. The starter, generator and air cleaner were semi gloss black. Engines were painted fully assembled less starter, generator, fuel pump and carburetor. | | |
#51860 11/03/2005 9:05 PM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I'm in the process of putting a new 235 into my '40 GMC. The trans and bellhousing were not painted at all. The original engine was blue/gray. But mine's a Canadian model and had a 224 in it rather than a 216 that it's US cousin uses. Your tranny paint should be fine. You can see photos of mine here: http://community.webshots.com/user/ndnchf Steve | | |
#51861 11/04/2005 4:41 AM | Joined: Apr 2004 Posts: 17 New Guy | | New Guy Joined: Apr 2004 Posts: 17 | ndnchf, your photos are great, I am in the process of rebuilding by 54 235 and will be a great resource. Thanks for asking the q 3 girls, I was wondering myself! | | |
