| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I bought new lines from Jim Carter and they were supplied with(2) right angle brass fittings. The rubber lines thread into this fitting and this fitting threads into the filter housing.
I contacted Carter and their response was they don't have any. I don't mind buying them myself but I don't know how to properly identify them. Can anyone help me out with what these are called?
Keith | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Keith, You state you were supplied with the fittings by JC - did you mean "were not supplied"? Here is the Weatherhead-Eaton brass fittings catalog. These part numbers work at NAPA. They even have the T-fitting for the block (for the oil pressure line and oil filter line). Tim | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | The threads in the filter housing are most likely 1/8 inch female pipe. The rubber lines will probably have 1/4" flare nuts on both ends. You would need a 90 degree elbow with a 1/8" male pipe thread on one side, and a 1/4" male flare thread on the other side. Any good FLAPS should be able to supply those fittings.
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks guys-
Tim I did receive the fittings from JC..There a good outfit this is my bad..I either misplaced one or mangled it somehow last lear and tossed it-
Thanks Lincoln...
Looking at the catalog and see on that looks good.
Keith | | |
