7 members (Jon G, Wayne67vert, KEVINSKI, 50Chevy3100, 1955 1 Series, sron48, 1 invisible),
46
8
Mod | | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | When i turn on my blinkers they blink really really fast, both the lights in the cab and in the back. I see this on modern cars all the time. What is the problem behind it? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | The flasher is the little device that makes the lights blink when you indicate a turn. It's a small cylindrical can located underneath the dash or stuck in the fuse block. If you park in a very quiet place and indicate a turn, you should be able to hear it going 'click-click' in time with the lights.
If this little device is undersized for your amount of lights, it will blink rapidly. Pull it out, take it to your auto parts store and ask for a heavy-duty version.
This is assuming that this is your problem. The more lights you have blinking left or right, the more current you are drawing which means the flasher will blink faster.
Stuart | | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | It's the little metallic drum thing under my fuse box. But ive had that flasher since i got the truck and blinkers have been normal. It started when the dual filament plugin fell out of the rear light holder and one of my blinkers stopped working so i got out and plugged it back in. Now both blinkers blink really fast. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Turn signal problems can be deceiving, but going with the odds, I would check whatever you did on the taillight that caused the problem. Is there any chance something was plugged in backwards?
Stuart | | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | possibly, i'll check it out | | |
