6 members (Phak1, Bill Hanlon, Greg_H, dt235sd, Jon G, Oswald), 131 guests, and 2 robots.
Topics128,090
Posts1,056,384
Members48,442
#518379 03/18/2009 5:46 AM
I took my brake and clutch stuff out a while back and I'm ashamed to say I don't know how to put everything back together. I've got a pile of parts here - the pivot, the clutch and brake levers that go on it, a bunch of washers...does anybody have a diagram of how this all goes back together? Thanks!
Someone probably does. But they'll need to know what model truck you are working on.
Sorry! Its a 1952 3100
I got a 52 3100 to ,I took pics of what You need check My pics, Pete
http://s559.photobucket.com/albums/ss39/sparky52/
Thanks Pete, that does help some. I think I also need an exploded pic so that I know if I have all the parts - I think I'm missing the outermost clip that holds everything together.
Best thing to do is get a factory assembly manual it is a reprint it shows You every thing on our trucks I mean everything nuts , bolts and washers all frame parts and how it was assembled at the factory , Pete
I tore my house apart today looking for the factory assembly manual - I knew I had one around here somewhere - and miracle of miracles, I actually found it!
With the help of your pics and the manual I figured out that I had everything except the outermost clip. One trip to the hardware store and a $.30 e-clip later I had everything together. Thank you!
Good luck on Your truck, Pete
