| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | Does anybody know where I can get spedometer gears. For my 1946 chevrolet 3/4 ton truck it has a 4 speed transmission and has a rear axle out of 1981 3/4 ton that has 3.73 gears. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | If you are looking to get your spedo to read correctly, you can go to almost any good spedometer shop and they can build you an adaptor for your spedo cable that just screws on to your trans. An easy fix. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Bow Tie Overdrives at www.700r4.com has speedo gear info that may be of help.
Evan
