9 members (artinva, Gdads51, 1955 1 Series, tesa, JW51, Peggy M, VicZ, Ridgeback, 1 invisible),
93
0
Mod | | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Any help on tear down. I got one tore down, well apart. The rubber is still on the rim and the other piece. I took out the thin strip that hold it together then used a saw-a-zaw to cut the tire apart, to separate the other two pieces.
Is there a better way to do this and how do I remove the rubber from each piece??
~This may have been discussed before, if so, please link to that post.
Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are not saving the tires or tubes, that is in my opinion the easiest way to get them apart. You can use some kind of solvent to release the rubber. Gasoline would probably do it but of course it is a hazard. | | |
