1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#518267 03/18/2009 2:11 AM
Any help on tear down. I got one tore down, well apart. The rubber is still on the rim and the other piece. I took out the thin strip that hold it together then used a
saw-a-zaw to cut the tire apart, to separate the other two pieces.
Is there a better way to do this and how do I remove the rubber from each piece??
~This may have been discussed before, if so, please link to that post.
cshamel #518271 03/18/2009 2:22 AM
If you are not saving the tires or tubes, that is in my opinion the easiest way to get them apart. You can use some kind of solvent to release the rubber. Gasoline would probably do it but of course it is a hazard.
1951 1 Ton Completed
