| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 22 Apprentice | | Apprentice Joined: Jul 2007 Posts: 22 | All,
I am looking for someting or someone that can illistrate or describe how to assemble the hardware to mount the cab to the frame. I purchased a kit but, for the life of me, I cannot figure out how these parts fit!??! I think I have the front mounts figured out (emphasis on the 'I think') but the rear are a mystery.
i have searched the forum for answers on prevous posts but I seem to be the only one to ..... i won't finish the sentence...
Ron
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Ron. I'm not sure if this applies to the 1 ton but I hope this points you in the right direction. Have a look at this pic . Sorry it's a bit dark but you can see the rear cab mounts on the chassis. They are almost like shackles. Good luck Jock
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2007 Posts: 22 Apprentice | | Apprentice Joined: Jul 2007 Posts: 22 | Jock, thanks for the info. It was exactly what I needed.
It seem like I need to get the rear mounding hardware, a bracket that mounts on the underside of the cab and a "U" shaped bracket mounts on the frame crossmember.
Ron
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I think there is a left hand and right hand bracket,so check which one goes where
just a thought
| | | | | Joined: Jul 2007 Posts: 22 Apprentice | | Apprentice Joined: Jul 2007 Posts: 22 | Just-a-hacker,
thanks for the feedback .... you are correct about the rt\lt brackets. the cab i have only has the passenger side bracket so I will have to dig up a rt hand one.
Ron | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I think there is a left hand and right hand bracket,so check which one goes where
just a thought You're right. There is a left and right. The part that mounts to the chassis allows for the taper, I only found this out myself when I re-installed them!
