| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51824 11/01/2005 10:50 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I'm thinking about using a hydraulic throw out bearing and 3/4" master cylinder attached to the stock pedal when I put a T-5 in my '51 half-ton using the original bell-housing (and engine). I got the hydraulic bearing and master cylinder from Summit for about $200.
I can't bolt the clutch master cylinder behind the pedal arm because thats where the brake master cylinder is. So I'm going to put it on bracket mounted to the frame rail forward of the cross member and use a rod between the pedal and master cylinder rod to pull the rod into the master cylinder rather than push it.
Does anyone have any experience with this or suggestions to offer?
#51825 01/15/2006 8:39 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Hello, Did you ever finish your conversion? How's it working out for you? | | |
