1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#517811 03/16/2009 9:55 PM
Does anyone know where the horn relay lives in a 41 chevy?
A picture would be awesome.
Thanks!
41chevy!! #517821 03/16/2009 10:56 PM
41chevy,
I'm not 100% sure on this but I don't think a horn relay showed up on a Chevrolet truck for another 10 years or so.
Stuart
atomarc #517827 03/16/2009 11:25 PM
weird......my wiring diagram shows one?!!?
41chevy!! #517835 03/16/2009 11:57 PM
41chevy,
Who supplied the wiring diagram that shows a horn relay? I looked at a '40 factory diagram and a '42 factory wiring diagram. Both identical and neither has a hint of a horn relay.
If you look at your bone stock '41 horn, it probably has two small screw terminals on it. This means no relay. One terminal is battery power from ammeter and the other supplies the ground to the horn through the horn button on the steering wheel.
I think a horn relay in 1941 would have been have been akin to space travel in 1950. I have certainly been wrong before though.
Stuart
atomarc #517841 03/17/2009 12:07 AM
The first year for the horn relay was 53.
AD_Pickup #517843 03/17/2009 12:22 AM
OLTrucks
Unregistered
OLTrucks
Unregistered
If I remember right cars had horn relays much earlier then 1953.
Mike
#517845 03/17/2009 12:40 AM
Ex Hall Monitor
Ex Hall Monitor
Depends on whether they had the accessory (town & country) horns or not. My 38 has a relay on the accessory horns but it doesn't come in to play with the stock horn mounted on the manifold. The relay is mounted to the accessory horn bracket between the horns.
Tiny #517856 03/17/2009 1:32 AM
The original question was about a '41 truck wasn't it.headscratch
Stuart
atomarc #518039 03/17/2009 1:52 PM
Ex Hall Monitor
Ex Hall Monitor
The accessory horns were available on trucks I've been told. Also wiring diagrams were generic I believe, not discriminating between a car or truck. He advised his diagram showed a relay. ohwell
Tiny #518132 03/17/2009 7:34 PM
Just to further confuse this discussion, here are 1941 Shop Manual wiring diagrams for car and truck. My guess is that the two diagrams are mislabeled: the truck's is probably the one on the top - one horn and no relay; and, the car's diagram is probably on the bottom - a relay and two horns.
tclederman #518134 03/17/2009 7:39 PM
OLTrucks
Unregistered
OLTrucks
Unregistered
Tim now when do you ever "confuse".
tclederman #518154 03/17/2009 8:56 PM
Ex Hall Monitor
Ex Hall Monitor
Here is the diagram for both car and truck in 38. The accessory horns came with their own diagram. My harness came with a copy of it. If I still have it I'll scan & post it.
tclederman #518210 03/17/2009 11:33 PM
This is the diagram I have and I think you are right, it is miss labelled.
41chevy!! #518329 03/18/2009 3:29 AM
Agree all around:
Diagram is mislabeled.
Horns had NO relay originally in '41.
Can't speak to accessories.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
