| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | All, Saw this on X-treme 4X4 Saturday. Looked it up and it appears to be the perfect solution to the Ampmeter wire running through the firewall, shorting out, and burning your truck up. I have ordered one. I feel this, along with the voltmeter idiot/charge light, will overcome the arguments on the pros and cons of each. It is so simple - get both and benifit from them while eliminating the primary argument. We get all that power safetly crossing a metal firewall. More than I had expected cost wise, but far less than the cost of my truck! http://www.painlessperformance.com/webcatalog/Keywordsearch.php?partsearch=firewallCavebull | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Just had a thought. If someone was willling to split the cost with me, I would give you choice of color. Cavebull
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Cavebull,
I wasn't aware there were any long running safety concerns with running a wire through the firewall. On the trucks I have seen, there is a rubber grommet that adds protection to the large, well bundled and insulated run of wires that penetrates the firewall.
The wires are quite rigid and it seems like it would take a terrific amount of constant wiggling to cause them to short against the metal of the firewall.
Stuart | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Hey Stuart, I tend to agree with you. Those with the most concerns seem to be those wired a different way, sell re-wiring kits and/or volt meters. Otta search sometime. It is amazing how much contreversy there is over volt vs. amp. You would think it was the thrilla' n Manilla for christ's sake. I am hesitating on purchase since I am not forking over 75 for two when one was a just in case - besides I am up to my neck in stering and sway bars.
Cavebull | | |
