| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51788 10/31/2005 6:53 PM | Joined: Nov 2004 Posts: 19 Junior Member | | Junior Member Joined: Nov 2004 Posts: 19 | Hello Bolters.
I've got a '66 292 that runs well but I want it to run better. Got a stock carb on it now.
Got any ideas for a better, after-market carb?
Thanks!
---Scoob, Tucson | | |
#51789 10/31/2005 9:59 PM | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | There are lots of options, but you'll have to swap manifolds. there are a number of small four barrel carbs that will work good; the holley 390, and edlebrock 500, are two favorites. If you are not interested in swapping to a 4 barrel, you may want to check the numbers on your present carb, and make sure it is actually a 292 carb. A lot of those engines ended up with the smaller 230-250 carb on them. I can't recall the numbers for each, and I don't think I have the info anymore, but I'm sure one of the guys on this board can help out. With a 292 I'd plan on swaping to a small 4 barrel. One other option is a Holley/ Weber 5200 2 stage 2 barrel. You can get an adapter to mount it to the stock manifold. It is a much better carb than the stock one, but it is not big enough to make any real difference on perfomance. I did notice a little better acceleration and about 5 mph on the top end using one on a worn out 250. The main improvements were cold starting, and all around drivability.
Boo
We don't need no stinking V-8s!!
#51790 11/01/2005 5:07 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Boo's got it right, sorry to hear about the 5200 though. I have a 63 with a 292 and I played with the Rochester one barrel and replaced it with a Monojet. Didn't get as much performance increase as I did dropping in an HEI and playing with the advance. Still not much, got 11 mpg. Carefull though on the advance curve, best have a shop set it up to match the original dizzy. Boo any comments on mileage between the 1, 2, and 4. Thanks, Larry
I don't own a vehicle that isn't old enough to drink. | | |
#51791 11/01/2005 2:02 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | There are Zenith and Stromberg single barrel carbs that will improve the performance.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#51792 11/01/2005 3:59 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I run a Carter 625 AFB on an Offy manifold on my 292. Runs great. I love the electric choke. People told me I'd lose low end power and mid-range throttle response...but that hasn't been the case. It's a very driveable, fun combo, especially with split headers and Cherry Bomb glasspacks. It's not very subtle, tho.  | | |
#51793 11/01/2005 5:07 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I'm just going fuelie with my 250...  | | |
#51794 11/01/2005 11:01 PM | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | Believe it or not the best mpg I got was with a new-rebuilt monojet from NAPA! But I have 4:11 gears so I spend a lot of time in the upper rpm range and way into the secondary with the 2 barrel. With the monojet holding to around 55 mph on the hiway I got 16 mpg.
Boo
#51795 11/02/2005 5:32 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Thanks Boo! I've got a 4.11 and I'm hauling a Big Camper. I like the Monojet. You get to the power valve fairly easy. Now if a Zenith or Cater were to show up on my door step I'd like to play with them. Larry
#51796 11/02/2005 9:12 AM | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | Originally posted by LGriffin: Thanks Boo! I've got a 4.11 and I'm hauling a Big Camper. I like the Monojet. You get to the power valve fairly easy. Now if a Zenith or Cater were to show up on my door step I'd like to play with them. Larry I've thought a lot about trying duel monojets. You can buy a new-rebuild for $139 from NAPA and $99 from JC Whitney. However, I don't like the long warm up time, and I HATE that stumbling just off an idle that every one I've seen has. I asked my Dad how to cure that, and he said, "Throw it away and buy a carburetor." Boo
#51797 11/03/2005 1:10 AM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Boo - your Dad gave you excellent advice! ChevyAsylum - the Carter 625 will certainly run better than the Rochester one barrel (so will pouring gas into the engine out of a boot); however, experience tells me you would like a Carter 500 (Carter number 9500s) better than the 625, and would just be estatic over a Carter 400 (Carter number 9400s). Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
