0 members (), 107 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
The distributer cap on my '97 GMC with 350 (5.7) is loose. One of the screws just sits there and spins. I changed the cap and the screw just pulls out with no bite at all. Is there a better solution than to just stick a larger screw in there or will that just mess it up more. The service engine soon light is on and it's running like crap. I'm a little bit [censored] off at the whole situation but need to spend the time constructively and get it fixed.
Gravity - It's not just a good idea, it's the law.
Loctite makes a product called "Form a Thread". It's a kit that has two parts, works pretty well.
You never have enough, til you have too many!
Try a dab of J B Weld in the screw hole.
Let it set up,Drill and retap it stock size.
Thread pitch gauge should tell if STD/Metric.
Did this on a 88f150 W/a 300 six All the screws were stripped out.Worked like a charm.
wink
Regards Steve sr.
Bill G.,
Just went thru this with my 93 Chevy 350 engine; Service engine soon" lite. It was throwing a code 13 on the scan tool. Thats 02 sensor. The sensor was reading lean. So I changed the o2 sensor and fuel filter while I was at it. Everything fine now. The fuel filter I couldn't blow thru so it was probably the filter putting it into a lean condition. Try that as well as your dist cap issue. Good luck let us know.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Moderator
Moderator
Yeah, be sure to check the code and find out what it means. A lot of shops do this for free.
On my '89 Suburban I had the HEI distrubutor rebuilt. They have some inherent problems that tend to show up after 100k miles or so that will make it run really bad. If you assess the whole unit, there may be more to fix than just the obvious problem. I would at least take it to a Mr. Goodwrench and get an estimate and explanation.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
