0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#51772 10/29/2005 9:59 PM
A rear brake on my 46 pickup hangs up sometimes. I just drive anyway and it seems to loosen up. But what do I need to fix?
#51773 10/29/2005 10:15 PM
Probably the retracting spring is broken. If so, the brake drum will be really tough to remove.
#51774 10/31/2005 2:44 AM
Welcome aboard pistachioted. I'm going to move your question to the engine and driveline shop for a little more attention. smile
#51775 10/31/2005 2:49 AM
You may also have a leaking wheel cylinder. If the brake lining absorbs brake fluid it will stick to the drum. Best to pull it and have a look.
#51776 10/31/2005 4:04 PM
Quote
More like nigh impossible...
If your spring is busted, then you're going to want help. The technique I use is "Here, you pull on it while I wang on it with a hammer."
Quote
Agreed.
#51777 10/31/2005 10:41 PM
Riding in the Passing Lane
Agree also. It is either brake fluid leaking or grease leaking from the axle seal. Possibly could be the emergency brake adjusted too tight or cable sticking.
1972 Chevy c10 Cheyenne Super
