4 members (Otto Skorzeny, Materman, mason86, GRNHydra), 100 guests, and 2 robots.
Topics128,069
Posts1,055,890
Members48,428
#517679 03/16/2009 5:52 AM
Z
zuk
Offline
Z Offline
have a 216 and want to paint the vent tube on the engine but can't get it off.can any one tell me how?
zuk #517705 03/16/2009 12:14 PM
There is a strap on it that is secured through a pan bolt. After removing the bolt, tap on the vent with a rubber hammer while pulling and wiggling it from side to side. The bottom of the pipe is tapered and is a friction fit into the block.
1951 1 Ton Completed
zuk #517706 03/16/2009 12:14 PM
Remove screw and spacer from bracket at the oil pan. Using a soft hammer tap draft tube back and forth slightly while pulling up on it. It may take a few minutes but it will eventually come out.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I got ticked off and made a puller from a piece of inner tube, pair of visegrips and a slide hammer that did the trick. I wiggled that tube back and forth until I was blue in the face. Had to try something else.
David B
