1 members (Steelonsteel),
125
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 5 New Guy | | New Guy Joined: Mar 2009 Posts: 5 | have a 216 and want to paint the vent tube on the engine but can't get it off.can any one tell me how? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There is a strap on it that is secured through a pan bolt. After removing the bolt, tap on the vent with a rubber hammer while pulling and wiggling it from side to side. The bottom of the pipe is tapered and is a friction fit into the block. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Remove screw and spacer from bracket at the oil pan. Using a soft hammer tap draft tube back and forth slightly while pulling up on it. It may take a few minutes but it will eventually come out. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2008 Posts: 308 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 308 | I got ticked off and made a puller from a piece of inner tube, pair of visegrips and a slide hammer that did the trick. I wiggled that tube back and forth until I was blue in the face. Had to try something else.
David B | | |
