7 members (klhansen, 87GN, tclederman, Stovebolt48, Peggy M, baldeagle, 1 invisible), 117 guests, and 1 robot.
Topics128,048
Posts1,055,666
#517262 03/15/2009 4:35 AM
Z
zuk
Offline
Z Offline
HI, I have 1950 1/2 ton with a 216 it was sitting for 10 years got it to start but the intake valves get stuck, and have to pound with a hamer to get free, why?
zuk #517325 03/15/2009 11:39 AM
Ex Hall Monitor
Ex Hall Monitor
Using old gas. If you're running it with gas put into an old fuel tank that hasn't been cleaned the new gas will dissolve the old gas/varnish which will become varnish again when you shut it off & the fresh gas evaporates, sticking the valves shut. Clean or replace the old tank, lines & fuel pump & the problem should go away.
Tiny #517668 03/16/2009 5:24 AM
Z
zuk
Offline
Z Offline
thanks,I did not clean the tank I thought a new filter would do it . and the main line was plug pretty good to.
