2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 5 New Guy | | New Guy Joined: Mar 2009 Posts: 5 | HI, I have 1950 1/2 ton with a 216 it was sitting for 10 years got it to start but the intake valves get stuck, and have to pound with a hamer to get free, why? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Using old gas. If you're running it with gas put into an old fuel tank that hasn't been cleaned the new gas will dissolve the old gas/varnish which will become varnish again when you shut it off & the fresh gas evaporates, sticking the valves shut. Clean or replace the old tank, lines & fuel pump & the problem should go away.
| | | | | Joined: Mar 2009 Posts: 5 New Guy | | New Guy Joined: Mar 2009 Posts: 5 | thanks,I did not clean the tank I thought a new filter would do it . and the main line was plug pretty good to. | | |
