4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#516963 03/14/2009 8:18 AM
well my 52 is done but i mounted my tailights on what i thought were stock mounts but when the back bumper is in place you cant see the plate cops wont like that i see from pictures some are mounted right up under the tailgate is this a stock location or have they been relocted thanks for help
Isn’t your ’52 the same as this??
http://www.pbase.com/dennygraham/image/110181851
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
hi Denny yes but the light braket is mounted on the back side of the postwith two bolts that run trew the post im going to get two new mounts and see if i can get them moved out and up thanks..
from the looks of yours mine have been changed they do bolt with those lower bolts but on the wrong side of the post
Jim & Caroline
