2 members (Dennys28, 1 invisible), 93 guests, and 3 robots.
Topics128,059
Posts1,055,818
#517145 03/14/2009 9:58 PM
I have a 1970 GMC Custom Camper Special. It has four wheel drum power brakes. I've heard from some of my dads friends that have owned one of these era trucks that I should get disk brakes for at least the front. Although I'm 13 and have only driven it in the neighborhood at about 10 or 15 mph, it still seems like they have just as much stopping power as the four wheel disk minivan. Could someone please explain the advantages of disk brakes aside from the easier replacement?
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
Reedster #517150 03/14/2009 10:22 PM
I'd say there's no "real" advantage over what you have - the drums [kept in good condition] will do as good a job .... until you're in a position to spend most of your time in the fast lane with heavy loads, put your cash and effort into more important things - front discs [not rear] would be a relatively easy "upgrade" for that year, but not at all necessary, might only give you added fade resistance
Flxible #517152 03/14/2009 10:30 PM
Thanks Bill.
The real test of stopping power is from a higher speed after the brakes have become hot. Then it will make a difference, and I'd say its worth the effort if you are going to drive this truck at highway speeds in the future.
Is this truck a 1/2-ton or 3/4-ton?
OldSub #517284 03/15/2009 5:22 AM
My truck is a heavy 1/2 ton with rear leaf springs. When my dad and I drove it home, he said that he couldn't tell a difference. I've got about a year and a half till I can drive it, I'm planning to to do a sort of resto. So if I have money in the budget after the other things I'll look into it.
Socket Breaker
Socket Breaker
My 1965 c10 long bed still has drum brakes(vacuum power boost assisted master cylinder) on all four wheels. I have had my truck since April of 2003 and as long as I keep in mind the limits of it's stopping power, I have no problems unless other people get involved.
As long as the internal metal hardware and springs within the drums are in good shape and the shoes are not worn, you should be fine. Taking into consideration the lines and master cylinder and everything else is in proper working order.
The internal bits and pieces to rebuild the drums are available from parts stores.
Drum brakes when they get wet do take longer to stop. Drum brakes will lock the wheels up on you if you stomp on them, so try to remember to pump the brake pedal if you get into a situation on the road.
As Red58 noted, you could swap out to disc brakes on the front. Most of the kits to swap disc brakes into even older model trucks use a lot of the parts and pieces from the 1967-1972 trucks.
It is an added expense and it is all about if you want to spend the money or not. There have been before and after tests of disc brake swaps on older trucks, with the disc brakes stopping sooner. However, I don't recall reading about any before and after swap tests done with it under load.
Always remember it is a truck, it was designed to haul things under load. It is not a sports car. Let off the throttle sooner and ease into the brakes. When the bed is unloaded and you have to get hard into the brakes because of a situation you will feel the bed wanting to whip around.
Think when you drive and you should be just fine, as long as you keep everything in good mechanical order.
-W
