0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Can anyone tell me what the trick is to removing the water pump pulley on a GMC 248 engine? It's press fitted. Is there a special puller or something?
Glory Bound...
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | it might be tack welded. i was told to drill out the tacks and it comes right off. i was working on removing a pulley from a 270 last night and all but destroyed the pump trying to get it off. i gave up. it was a junk pump to begin with so i had nothing to lose.
why are you trying to remove it and what is the width of the pulley? | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I finally got it off just to find out I didn't have to. I took it in to get it rebuilt and the gut told me that it wasn't necessary to remove the pulley in order to get to the bolts. Oh well, live and learn I always say.
Glory Bound...
