3 members (Chris's 46 / 515, 59 fleet, Wally / Montana), 138 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
Apprentice
Apprentice
I have a 1955 235 from a car that i have rebuilt. I want to put it in a 1962 chevy 1/2 ton truck that has been robbed of all of its mounting brackets . Is this marriage legal in my state, and what is the best way to make it work. thanks! Rick in dallas
3B Offline
Hy rick tool, I'm not positive, but I think that engine has all the correct bosses on it to mount into a 62 truck, you will need to aquire all the necessary brackets of course. As to the legality of the swap, you will have to check with your states D.M.V. or eqivalent. All of todays vehicles have a V.I.N., back in 62 the vehicle could have been registered using it's serial number, or its engine number, you will have to verify which way the 62 was registered. In my jurisdiction we are technically required to notify the Motor Vehicle Branch when we swap engines, although it is rarely actually done, hope that helps.
Apprentice
Apprentice
Thanks shop shark , I ordered some front mounting brackets on line but they don't look like anything I have seen around the junk yard . I wouldn't mind welding something up but the engine looks so nice I don't want the rest to look hinkey.
when i got my 62 1/2 ton and looked up the engine no. (235) it came from a 57 car,and it has holes for brackets on the side of the block and under the harmonic balancer. mine has the front mount to the crossmember..Mark
Apprentice
Apprentice
Is that what they call the wishbone ? It seems like there is more than one way to skin this cat. does it mater witch method I use ?
