2 members (jay d, Gdads51),
75
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Well, I could use a bit of help here. My '63 C20 has the optional windshield washer. I have yet to test the pump, but I was eyeing things just in case I do need to replace it. Now, there is no replacement listed for a '63, however, there are ones listed for '64-'66. So, if any of you guys have a '64-'66 with a windshield washer pump, would you take some pics so I can see for sure if the pumps are the same? Or if one of you knows for sure that they are the same could you let me know? I am thinking they are the same, just minor variances, but I would like to find out for sure before I shell out money for something that isn't going to work.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I gotta bump this
| | | | | Joined: Nov 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 59 | Mike, if nobody has posted by tonight I will try to get a couple of pictures when I get home. | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | That would be greatly appreciated!!!
| | | | | Joined: Nov 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 59 | Mike, I don`t have a washer pump for my truck. The truck didn`t run when I got it so I never knew if it had one or not, but I looked. I did however find a drawing in my assembly manual and it looks like they use a different wiper motor and pump. The first picture form the way the dash looks is an older motor and the second picture looks like a 64-66 dash. http://www.picturehosting.com/images/AUSTIN64/1960.jpghttp://www.picturehosting.com/images/AUSTIN64/1964.jpg
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | The '63's use the same wiper motor as '64-'66. That was the changeover year, and that's why I'm thinking they use the same washer pump. I forgot I had an assembly manual, so I'll dig mine out and look through it some more. I really appreciate you taking the time to look at your truck as well as posting the images. I owe you one
