0 members (),
116
Mod | | | Forums66 Topics128,090 Posts1,056,378 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | I'm having the complete floor replaced along with the back corners of my 53 AD pickup. They think they can do the job for under $2000. Is this price within reason? I can do the mechanical but body work is completely new to me. Tell me what you think. Another thing this shop uses TIG rather than MIG because they say it does a better job. Please advise me and thanks in advance----- | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Funton, having a bodyshop in the past, but retired now, replacing both cab corners and replacing the complete floor the price sounds reasonable....I replaced the complete floor in My 52 and both cab corners too...I drilled out all the factory spot welds, then drilled the new panels in 1 1/2 increments, then used My mig to duplicate factory spot welds...looks great.....now I didn't have a tig to compare which is best, but I am sure either one would be good...Bill B | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Is the cab on the frame? Does that $2k include parts? If so, it's a great price otherwise it sounds reasonable and any shop that uses TIG welding is probably going to be more meticulous.
Both MIG and TIG will weld two pieces of metal together, but TIG is neater with a smaller bead and more control over burn through and penetration. The downside of the TIG is the cost of the equipment and complexity of operation. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think that is an amazing price. I would assume "floor" means from the seat forward. I don't think they could do a whole floor replacement for that price.
If they haven't seen the truck yet, they may have to add things like inner corners at the rear and all four floor supports. | | |
