| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51546 10/27/2005 12:18 AM | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | Just purchased a water pump for my 39 216 engine and noticed that the parts listing showes the 39 water pump different from the 41 and up 216 engines. There seem to be a number of differences (oil pump, spark plugs) What is the difference in water pumps? Do parts from these two vintage engines interchange? Are the differences significant? | | |
#51547 10/27/2005 12:29 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | In my experience, I believe I only ran across a couple of significant differences between a 39 and a 46 216. I wasn't aware that a water pump was one of them.
I spent last winter putting a 1939 216 in my 46 truck.
If memory serves me correctly... Different crank, flywheel, and flywheel mounting flange, (4 bolts vs. 6 bolts with keepers, if I remember correctly). I believe there are some differences in the rear seals. There is also a different oil distributor location.
Ran into problems with that last one, when I had my manifold split according to measurements I took off of the 46, rather than the 39 block.
I'm going to have to look at the water pump I pulled off of the 46, when I get home this evening. I had saved it, so I'd have a spare if I ever needed it. | | |
#51548 10/27/2005 2:09 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1937-40 216 pumps only have one water hole where the water flows into the block, 1941-54 have two. The bolt pattern is also different.
1940 was the first year to use a rear main seal and a six bolt flywheel. 1940-41 flywheels are the same but use 3/8" mounting bolts and have a larger center hole than 1941-62.
See the USA in your vintage Chevrolet! My Blog | | |
#51549 10/27/2005 2:15 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | There are quite a few differences between 37-40 and 41 on up. Chevrolet did a redesign of the 216 and except for the cubic inch displacement, most of the internals were changed and reworked to the point that even the oil pan has a different configuration, along with the bottom of the block. A gasket set for 37-40 will not fit a 41 on block. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#51550 10/27/2005 2:36 PM | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | Thanks for all of the comments. They help clear up the mystery. This is the kind of information that only comes from experienced stovebolters. | | |
#51551 10/27/2005 9:55 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Somewhere in there, I believe 1939, they added the oil sprayers for the dippers. | | |
#51552 10/28/2005 1:39 AM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | Don't know if this is any help or not, but on my webshots pages, under the 224 to 235 engine swap album, photo 7_22_3 is a photo of the front of my original 1940 motor with the water pump. This is a 224 motor, the Canadian cousin of the 216. The only difference is it uses aluminum pistons instead of cast iron and they are a tad larger in diameter. http://community.webshots.com/user/ndnchf Steve | | |
#51553 10/28/2005 5:51 PM | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | ndnchf Thanks for posting the fine pics, what year is the 235? I have a 56 on the stand that i'm going to rebuild and install in my 46 2ton. This is new ground for me.
You never have enough, til you have too many!
