5 members (NJC, 32Fordpuchoptop, 48jim1ton, BillyDon, Jman), 94 guests, and 3 robots.
Topics128,042
Posts1,055,601
#515102 03/09/2009 5:14 PM
1 Offline
I have a 1947 2-ton chevy truck. Great running old truck but the engine I know is not original and I can't find out what year it is or for that matter what exactly it is. The Serial number is F112L (Maybe FII2L) and the casting number is CON 4 A78. I've looked through several numbers references and I still can't find it. Does anyone know what it is?
Here are some guesses at the codes:
F112L
F = Flint, MI manufacturing plant
1 = January
12 = 12th day
L = installed in a 6000 series truck
CON4 A78
A = January
7 = 7th day
8 = 1958
There might be different interpretation s of the above codes - people will post corrections, etc.
We will be able to tell you more, if you post a few more codes from the head and block.
1 Offline
I've heard of that coding, but how can I be sure it's a 1958 and not a 1968 or a 1978?
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
1947farmer,
There will be a long casting number on the side of the block. This number would be used for only a few years, so by knowing the casting number and date code you can ID the engine block. I don't believe any casting number ever lasted 10 years, they are always changing things which then makes them change the casting number.
Hope this helps!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #515701 03/11/2009 3:57 AM
Also, you motor could be a 48 if the side cover goes around the spark plugs and could be an early 235. The most important number is the casting number, should be below or near the fuel pump, usually hidden behind muck and oil. Also get the number off the head, will be another clue to what this motor is.
Good luck
1946 1/2-Ton Chevy
1 Offline
Thanks for the guidance guys. I got her figured out.
I miss read the one number (Should have been CON 4 A79 and after finding the casting number I was able to identify it.
It's a 1959 261ci!! The big one!
1947farmer
1947 2-Ton Chevy
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1955 Allis WD-45
1- 1976 Allis 7040
