6 members (Otto Skorzeny, 50Chevy3100, frogfarmer, UtahYork, Shaffer's1950, 1 invisible), 67 guests, and 3 robots.
Topics128,056
Posts1,055,804
#51458 10/24/2005 6:21 PM
Is there an easy way to test whether or not the vacuum advance is working properly on my 235???
#51459 10/24/2005 7:02 PM
Buckaroo01,
I am a little reluctant to say the best way would be with a timing light. This would tell you if the entire system works. You could test the diaphram by sucking on it, plugging it with your tongue and feeling the vacuum. You could pull the vacuum line off the carburetor while the engine was running and listen for a change in RPM. You would have to plug the vacuum port in the carburetor while doing the procedure.
Stuart.
#51460 10/24/2005 7:28 PM
Jed Offline
Buckaroo01,
On both, my 216 and 235, the distributor moves when I rev the engines.
I would assume, starting your engine, increasing the RPM's by hand, while watching the distributor for movement, would be the easiest way to determine whether or not the vacuum advance is working or not.
#51461 10/24/2005 7:55 PM
Try engine running disconnect & plug vacuum line. use timing light to see timing marks & apply vacuum with a hand vacuum pump.
Another simple test would be to with engine at idle disconect & plug the vacuum source. Check base timing. Increase RPM to check mechanical advance. Re-install vacuum line & retest. vacuum advance will be equal to total advance minus mechanical advance.
#51462 10/24/2005 11:05 PM
At curb idle, about 600 rpm, the vacuum advance should not operate, it should be in the "relaxed" position just like with the engine off. As you open the throttle past idle, the advance should pull about 8.5 degrees of distributor rotation counterclockwise (17 degrees crank advance) . It should snap back as you let off to idle.
Paint & Body Shop moderator
#51463 10/25/2005 1:09 AM
you can also suck on the diagphram with a tube with your mouth and watch the plate the points are on to see if it moves..
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#51464 10/26/2005 2:51 PM
Once again thanks to all, I'll give it a test this weekend.
