6 members (Wickedbass, jkreiner, mvigo, Charles in CA, Rusted Nut, 1 invisible), 75 guests, and 3 robots.
Topics128,074
Posts1,055,913
Members48,429
#514382 03/07/2009 6:46 PM
swaping rear end to 3/43 leaving stock six and orig. tthreespeed, what can I expect?
derry #514386 03/07/2009 7:00 PM
Derry I'm at a loss to help you because you offer so little information.
What year and model is your truck? What is the rear you are swapping coming from, year and model.
Are you asking about the impact on performance or the difficulties in the project?
OldSub #514445 03/07/2009 10:10 PM
1940 1/2 ton,rearend is out of an 87 s-10 4 wheel drive blazer.asking about impact performance...thanks
derry #514528 03/08/2009 1:49 AM
As Old Sub pointed out....you didn't offer much information. If you're trying to determine you ground speed/rpm you might use the following formula to give you some idea of the benefits of a 3.42 R&P.
http://csgnetwork.com/multirpmcalc.html
Keep in mind that the straight 6 Chevy engine is going to be happiest from about 1600-2400 rpms, although it can be run up another 500 rpms. These numbers put you into the torque band where the low-end torque will work in your favor. Plug in your rear tire height, the R&P ratio (3.42), 1:1 which will be your 3rd gear ratio and you can vary the speeds to see where you will be in relationship to the torque band.
I've found that my engine runs most efficiently towards the top of the torque band......1800-2300 rpms.
If you're asking about swapping from a closed driveshaft system to an open differential, you're going to be faced with a potential transmission change, a new driveshaft, and modifying the differential mounting system to bolt your Blazer diff to the stock rear suspension. You'll more than likely need to upgrade your master cylinder to a dual chamber and replace old brake components and adding modern shocks.
Challenging but not impossible if you have the time, experience, tools and cash to do the job!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Thanks for the info. I am just beginning to round up parts for the 40. I have a mustang 2 hub to hub kit for the truck fron southern classics. I am kicking around the idea of putting a 350, with a 350 tranny in it ,I will be pulling the motor and tranny anyway when I install the new front suspension. I already have the 350 and tranny on hand.
