3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
Hey everyone!been a looong time since I've posted,but was wondering if anyone has used diamond plate on the part of the running boards that you step on,I guess where the ridges are at where you step up into truck,thanks
don't know bout using diamond plate but i call our local metal fab shop minus the cost of the steel i can have new boards bent to the original specs on their break for 39 for both side originals are in good shape so i will recoupe the money spent on the new ones by putting the old ones on ebay grin and plus much more so i don't see why they couldn't bend diamond plate the same way i just prefer the smooth look
1937 1/2 ton
I used 13 gauge smooth steel and since steel checker plate is available down to 2.5 mm or roughly the same thickness I don't see why it won't work for you.
http://s176.photobucket.com/albums/w186/curt160/runningboards/
You Tube
Why not have the center plasma cut out and have someone bead roll some new sheet metal and weld it back in!
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Does anyone have (or know where to find) any replacement running boards for a 1968 LWB stepside?
I would like to find NOS, but no luck so far.
