| | | Forums66 Topics128,162 Posts1,056,945 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51428 10/22/2005 2:58 AM | Joined: Sep 2005 Posts: 12 New Guy | | New Guy Joined: Sep 2005 Posts: 12 | Hello I have a 47 AD with a 55 235 and 4 speed trans. (floor shift) I just purchased this truck and it is missing the flywheel cover. Can anyone tell me what will fit. I have found one from a 216 engine but havn't bought it yet as I am not sure if it will fit.
1947 Chevrolet "under construction"
#51429 10/22/2005 4:22 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Postal,
I'm no authority, but I believe it should fit. It's more than likely the stock 47 trans. behind that 235. | | |
#51430 10/22/2005 9:00 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Postal,
Most likely the determining factor is what clutch housing (bell housing) you have. If it is the original '47 housing from your 216, the 216 cover is what you need.
Most likely you do not have the '55/235 clutch housing because it has different motor mounts than are used on the '47 engine/frame. As I recall, the '55 clutch housing has two flywheel cover-pieces - I do not recall what the cover set-up is on a pre-54 clutch housing.
Tim | | |
#51431 10/22/2005 3:19 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | The earlier 216 clutch housing was also 2-piece. For lack of better terms, I'll call them the shield and the pan.
I wasn't aware there might be a difference, as my 216 and 235 both appear to be the same. "Appear" being the magic word, as I haven't measured them against each other. | | |
