| | | Forums66 Topics128,108 Posts1,056,236 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51418 10/21/2005 10:14 PM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | I'm brand new here. I've got a 1949 GMC farm truck with I believe a 228 cu in engine which was run hot by the PO and is now broke. I can pick up a pretty good '78 292 strait 6 for a couple of hundred $. Is there any reason I shouldn't swap this in? The Gmc has a front motor mount instead of the side mounts. I don't think that's a big deal. The length is about the same. I'm guessing the bell housing interface is the same.
Will this work? Anybody out there done this?
x x
#51419 10/21/2005 11:37 PM | Joined: Nov 2003 Posts: 53 Member | | Member Joined: Nov 2003 Posts: 53 | Unfortunately, the bellhousing pattern is not the same. The 'modern' inline sixes (194-230-250-292) all use the Chevy V8 bellhousing pattern. Its not a straight-forward swap. | | |
#51420 10/21/2005 11:51 PM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | Dang, thanks for the reply, you just saved me $200. I guess I'll open up the Jimmy and take a look.
x x
#51421 10/21/2005 11:56 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | The 292 is 1.75'' taller. Everything else, size wise is the same. The 292 has offset mounts on the side so you'll have to box the frame. Contact Buffalo Steve, Inliner advertiser, You can call Steve at Buffalo Enterprises - phone number: (360).652.7684 (do a search) and he can make you a mounting kit. You'll have to weld it in. Not sure about the 228 bellhousing but the 292 can take any chevy housing. it depends on what tranny you use. I would change to a more modern tranny than the 49 one you have as the 292 is torque'e. I am doing all this as you read on my 51. A new 292, T5, 12bolt etc...
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#51422 10/22/2005 12:25 AM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | That would make it easy to change out both engine and trans. together. This truck has a nifty p.t.o. arrangement on the trans. to work the dump box so I,d like to keep the original trans. If I can't do this with a transmission adaptor I'll rebuild the GMC. Thanks.
x x
#51423 10/22/2005 9:58 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You can get a mid-60s bellhousing that will bolt to that SM420 transmission...GM used those things forever. | | |
#51424 10/24/2005 1:49 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The '55 to about '67 V-8 pickup bellhousing is what you need. You'll need to build an adapter to mount the bellhousing to the crossmember, or replace the existing bellhousing crossmember with one from a '54 or '55 1st.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#51425 10/26/2005 2:49 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | |
#51426 10/26/2005 2:31 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Originally posted by cletis: Just keep it all GMC. Hey now, the '65 GMC pickup my uncle bought brand new has a 230 or 250 in it... :p | | |
#51427 10/26/2005 4:40 PM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | carolines truck, please keep me posted i have a 49 gmc suburban it has a running 248 engine, with a t-5 (s-10) and a 8.8 disc rearend 3:27 ratio. then the 248 dies i have a 292 to install. you can make a horseshoe u mount for the front under the crank pulley, to front mount it, like the original mount. | | |
