2 members (59 fleet, Otto Skorzeny), 120 guests, and 4 robots.
Topics128,070
Posts1,055,896
Members48,428
#51418 10/21/2005 10:14 PM
Junior Member
Junior Member
I'm brand new here. I've got a 1949 GMC farm truck with I believe a 228 cu in engine which was run hot by the PO and is now broke. I can pick up a pretty good '78 292 strait 6 for a couple of hundred $. Is there any reason I shouldn't swap this in? The Gmc has a front motor mount instead of the side mounts. I don't think that's a big deal. The length is about the same. I'm guessing the bell housing interface is the same.
Will this work? Anybody out there done this?
x x
#51419 10/21/2005 11:37 PM
Unfortunately, the bellhousing pattern is not the same. The 'modern' inline sixes (194-230-250-292) all use the Chevy V8 bellhousing pattern. Its not a straight-forward swap.
#51420 10/21/2005 11:51 PM
Junior Member
Junior Member
Dang, thanks for the reply, you just saved me $200. I guess I'll open up the Jimmy and take a look.
x x
#51421 10/21/2005 11:56 PM
The 292 is 1.75'' taller. Everything else, size wise is the same. The 292 has offset mounts on the side so you'll have to box the frame. Contact Buffalo Steve, Inliner advertiser, You can call Steve at Buffalo Enterprises - phone number: (360).652.7684 (do a search) and he can make you a mounting kit. You'll have to weld it in. Not sure about the 228 bellhousing but the 292 can take any chevy housing. it depends on what tranny you use. I would change to a more modern tranny than the 49 one you have as the 292 is torque'e.
I am doing all this as you read on my 51. A new 292, T5, 12bolt etc...
Jim & Caroline
#51422 10/22/2005 12:25 AM
Junior Member
Junior Member
That would make it easy to change out both engine and trans. together.
This truck has a nifty p.t.o. arrangement on the trans. to work the dump box so I,d like to keep the original trans. If I can't do this with a transmission adaptor I'll rebuild the GMC. Thanks.
x x
#51423 10/22/2005 9:58 AM
You can get a mid-60s bellhousing that will bolt to that SM420 transmission...GM used those things forever.
1954 GMC De Luxe COE
#51424 10/24/2005 1:49 AM
The '55 to about '67 V-8 pickup bellhousing is what you need. You'll need to build an adapter to mount the bellhousing to the crossmember, or replace the existing bellhousing crossmember with one from a '54 or '55 1st.
#51425 10/26/2005 2:49 AM
Just keep it all GMC.
#51426 10/26/2005 2:31 PM
Quote
Hey now, the '65 GMC pickup my uncle bought brand new has a 230 or 250 in it... :p
#51427 10/26/2005 4:40 PM
carolines truck, please keep me posted i have a 49 gmc suburban it has a running 248 engine, with a t-5 (s-10) and a 8.8 disc rearend 3:27 ratio. then the 248 dies i have a 292 to install. you can make a horseshoe u mount for the front under the crank pulley, to front mount it, like the original mount.
1949 SUBURBAN
