| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I was at the Ft Hood craftshop and they showed me a can of areosol spray to reduce/eliminate slag on flux core wire welders. It was a can about the size of a paint can marked Splatter Control. It did not stop all of it, but reduced about 90% of the trash my Harbor freight 110v flux core welder spit out...
Said to try at the local welding supplier.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brad,
The slag covering the weld is the byproduct of the burning flux that protects the weld puddle from the atmosphere, it's suppose to be there.
The spray stuff will coat the adjacent metal and allow the dingle berries to be wiped away without sticking, but it won't prevent the weld puddle from developing a slag covering. The intense arc burns it right off.
If you want a cleaner weld area, use a solid wire, or use gas with your flux core wire. This of course would require a gas setup on your welder.
Stuart
| | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Stuart I believe you said it better than I did, Thank you. My LIMITED welding experience I had never heard of such a product. My intent was informational to stir up a little discussion. There are at least a few bolters that might benefit from the info, like me not able to afford a better welder at this time. Once again, Thank you for the clairifcation . Brad | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | We used to have the spray but it was taken off our chemical list. We still have the dipping paste for dipping the nozzle in. It is spatter control and not a slag eliminator. | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | Stuart, you had it nailed....also, the slag covering slows the cooling of the weld....slightly, this is probably most important on body panels.
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Can you weld body panels with flux core wire?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Yes, you can but it's certainly not the cleanest or best method. Because the arc has to be strong enough to melt the flux located inside the wire, it tends to burn through thin material such as body panels.
Stuart | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If you ever weld with shielding gas, especially using .023 wire, you will never want to use flux core on body panels again. Flux cure has its place like out in the wind or for high amperage heavy welding, but it is easy for someone just learning to weld to get so frustrated with flux wire on body panels that they give up. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | The gas 20-80 co2 argon costs a little more but saves a lot of time. the only time flux core is handy is outside. The wind tends to blow away shielding gasses. | | |
