| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi guys, can you please tell me which one of the rims are the correct for my 3/4 ton chevy http://community.webshots.com/album/570398712fYSiZC?vhost=community, the red one has two lock rims and the green just one (external and wider)
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | The single lock ring what was standard on the older ones. the two piece came later. They are easier to change. Both of them were offered at one time on 3/4 ton. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | My 54 has single lock rings on all 5 of 'em. I'm not a big fan, so I've found some 8 luggers of a late model van that I'm going to use. You can use your oem hubcaps by installing some clips on the rims. It's all about safety bro! | | |
