11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9), 105 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#513425 03/05/2009 1:15 PM
Hello,
I have had a thought... and this may have done already.
I would like to ask if anyone has ever painted with a primer colored paint (gray,black)...then over with final color (green for example)then wet sanded higlight down to base color in typical wear areas...this to give the patina effect without going down to primer.This in conjunction with not removing all of the dents and dings may have just the look I want
Thoughts...experiences?
Thanks guys
mike
Morris #513433 03/05/2009 1:54 PM
Never tried that, but you may want to consider priming , a light color coat, then bufiing to achieve the worn effect.
I think sanding would leave obvious sand scratches.
Wally Body #513469 03/05/2009 3:59 PM
Hello,
Good thought.I like the dusting idea.
My purpose for using actual paint, colored as primer, was to have sealer.
Im a bit afraid of leaving unsealed primer.
Mike
mike
Morris #513549 03/05/2009 6:52 PM
If you use epoxy primer, it provides a good seal.
tclederman #513620 03/05/2009 8:52 PM
Good point...that may prove easier than sanding down.
Mike
mike
Morris #516147 03/12/2009 12:47 PM
The "new" rat rod guys have been doing that for awhile now. Wet sand your color in the "wear" areas down to the primer/sealer to give it the worn "mother nature" look patina.
