2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | Hey everyone!been a looong time since I've posted,but was wondering if anyone has used diamond plate on the part of the running boards that you step on,I guess where the ridges are at where you step up into truck,thanks | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | don't know bout using diamond plate but i call our local metal fab shop minus the cost of the steel i can have new boards bent to the original specs on their break for 39 for both side originals are in good shape so i will recoupe the money spent on the new ones by putting the old ones on ebay  and plus much more so i don't see why they couldn't bend diamond plate the same way i just prefer the smooth look
1937 1/2 ton
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Why not have the center plasma cut out and have someone bead roll some new sheet metal and weld it back in! | | | | | Joined: Mar 2009 Posts: 1 New Guy | | New Guy Joined: Mar 2009 Posts: 1 | Does anyone have (or know where to find) any replacement running boards for a 1968 LWB stepside?
I would like to find NOS, but no luck so far.
