I've been out of town, sorry for taking so long to reply-
It has been a couple of weeks, and I'm still EXTREMELY happy with the whole thing. Ordinarily I'd say it has good reception, but it isn't "reception" since it is hard wired. It sounds just as good as well-tuned radio stations or with the iPod with a new cassette adapter. It sounds like I hoped that it would.
I had some erroneous information in my first post that I'd like to correct:
I think it was a Dynex brand, not Belkin. I found a similar unit at
Parts Express that is only $39. (This one has a video input. The Dynex from Best Buy only had audio inputs.) If you talk to the car audio installers at Best Buy, they should be able to hook you up to a unit offered off the shelf.
The one I bought at Best Buy has an auto-switch in it, turning on only when a signal from the iPod is detected.
Here is a a similar unit but with an external on/off switch. However, unlike mine, this one has a pretty neat input level adjustment on it.
Here is the really cool adapter I used to make the connection, and turned an amateur job into a professional looking installation. I mounted this on an armrest so there are no wires to the dashboard. It also includes the male-to-male cable to go from your headphone jack. With these two components, you could be good-to-go.
However, depending on the head unit you are connecting to, it might be necessary to buy an
antenna adapter . Also, I was able to find a hot switched 12v lead at the radio, so I didn't need to buy a harness adapter. Your experience may differ, depending on your application.
I bought my FM modulator at the Weatherford Best Buy. Since you're in FW, I bet you won't have too much trouble finding one. PM me if you need more help getting one here locally.
