7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel),
94
Mod | | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51248 10/18/2005 5:35 AM | Joined: Oct 2005 Posts: 45 Member | | Member Joined: Oct 2005 Posts: 45 | I recently got a '65 C20, Original 292/6, longbed, fleetside. Truck was previously converted from a stock 4-speed to a car(?) 4-speed, with a Hurst shifter. I think this was not an uncommon conversion, as I have seen at least one other '65 with the same set-up. The floor was cut (cleanly) to accomodate the side-mounted linkage so the shift lever sits closer to the driver than stock. Can anyone can tell me what type of tranny I have? Gearbox has the number 3851325 stamped high up on the right side, along with some General Motors Patent Numbers. Standard H-shift pattern with reverse lock-out toward the driver and forward. What kind of trans have I got? | | |
#51249 10/18/2005 11:08 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#51250 10/18/2005 5:35 PM | Joined: Oct 2005 Posts: 45 Member | | Member Joined: Oct 2005 Posts: 45 | Thanks chuck. Do you know if this was a popular conversion for the period? Meaning somebody would have changed trannies to get better driveability, reliability or something like that? Better than the stock trans? Or just cooler than a granny-1st four speed? | | |
#51251 10/20/2005 6:39 AM | Joined: Oct 2005 Posts: 45 Member | | Member Joined: Oct 2005 Posts: 45 | By the way: The tranny rubber mounts on the rear carrier are kind of old and squashed showing the usual signs of age cracking. I can feel the drivetrain jump around slightly through the throttle pedal when I drive. Will worn out tranny mounts change the angle of the powerplant and, likewise, put additional stress on the driveshaft? What type of replacement trans mounts should I get for this Muncie M20, and who sells them? | | |
#51252 10/20/2005 11:09 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | A worn out mount won't help anything. Any good auto parts store (yeah - a dying breed) will have a replacement. Take the old one with, but I think old GM mounts are durn close to universal.
Why someone swapped the trans? A hundred guesses, none of which really matter. If it works, keep it. If not, lose it. | | |
#51253 10/21/2005 4:23 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Here's a couple of guesses why nthe tranny was swapped. The original 4spd was probably a SM420. The 420 first gear was non-synchro and so low that you had to shift before you got to the other side o the intersection. Not too mention not real easy shifting though better than a 465. The passenger car 4spd is synchro in all four gears and lot easier shifting. Most folks with the heavy duty 4spd don't use first gear, unless they've changed the rear axle ratio. I've only found first gear usefull on very few occassions. Larry
I don't own a vehicle that isn't old enough to drink. | | |
#51254 10/21/2005 8:57 AM | Joined: Oct 2005 Posts: 45 Member | | Member Joined: Oct 2005 Posts: 45 | Thanks Larry. Looks like these Muncie 4 speeds are used in Hi-Perf cars (Chevelles, 'vettes) so there's still a lot of parts available. This one's in pretty good shape. It's the only thing about the truck that's not original. But, it's a clean conversion so I don't mind. Shifts well, and makes driving the hills in San Francisco a lot easier. | | |
#51255 10/22/2005 9:43 PM | Joined: Oct 2005 Posts: 45 Member | | Member Joined: Oct 2005 Posts: 45 | Another (Stupid) question: How do you drain the oil on a Muncie M20? I see a filler plug, but no drain plug. Am I missing something? (except a few brain cells, that is) | | |
#51256 10/24/2005 1:55 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you don't want to keep the Muncie M20 make sure you have checked its value before letting go of it. There is more than one car-type Muncie, some are more valuable than others.
These transmissions have far more value than the SM420 that was original.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
