| | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 25 Apprentice | | Apprentice Joined: Feb 2009 Posts: 25 | Ok so Im almost done with the rewire. all that is left is to hook up the rear lights.But the parts store is out of the good terminal end. So I started to test stuff out an the flasher indicator stays on while in the off position. Everything else is working fine. Is it because the circuits are not done in the back of something else? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What????????????
~Jim
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Factory turnsignal or aftermarket.... usually with aftermarket t/s switches its lack of a good ground and backfeeding, try with rear lights hooked up....
Need more info for a Quality answer.... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the headlights are on you are getting feedback from the front lights. Could be hooked up wrong or poor ground at the front turn/parking lights. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
