8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86), 114 guests, and 0 robots.
Topics128,050
Posts1,055,671
#51205 10/16/2005 10:02 PM
I have a 1954 GMC 350 dump/flatbed with original 270. The exhaust manifold fits poorly; leaks with one combined intake port on cyls 2 & 3, and out exhaust port#4 despite new gasket & retorque @ 20ft-lbs middle studs and 30ft-lbs on outer studs. Is the manifold or head warped?
In the same vein, I have access to a rebuilt Chev 292 which is in near perfect shape, and with much less worn 4sp transmission. How hard would it be to fit this engine in the old GMC?
Thanks!
#51206 10/16/2005 10:45 PM
Not particularly easy. The side motor mounts are the biggest challenge and I think you'd find a fair bit of other tinkering. Take your manifolds off (bolted together), and have them planed at a machine shop. The GMC 270 is a good motor, I'd stick with it if the manifold is the only problem...even though the 292 is also a very good motor.
Are you sure it's a 270? The standard engine was a 248, I'm not sure if the 270 was available in the 2-ton line.
1954 GMC De Luxe COE
Yeah, I found the bore-stroke dimensions plate on the side of the block and it's a 270. When I rebuilt it I had to fabricate some exhaust valves and completely redid the head. It ran like a clock for a while then sprang this manifold leak that Ihaven't been able to fix. I'll try milling the manifolds - Thanks!
