2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#511805 03/01/2009 3:11 PM
on a 63 c60 apatche front brake are they self adjusting or no
GVW 19.500 292 5speed dump
http://s427.photobucket.com/albums/...n=view&current=dumpfrntbrakes007.jpg
1963 Chevy C60 Apache Dump Truck
Stovebolt Gallery Page
Photobucket pictures
No,
That little star wheel in your picture says it's a manual adjustment.
Not sure when self adjusting drum brakes came out, but
I'm thinking a lot later than 63?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
And I bet the rear brakes are manual adjust as well,
Grigg
The self-adjuster type will have a very fine-toothed star wheel and some linkage or a cable connecting it to the top of the brake at the anchor pin just above the wheel cylinder. It adjusts when the brakes are applied in reverse, but only when there's enough shoe movement to indicate the lining has worn.
To adjust that one, go through the slot behind the starwheel with a screwdriver or a brake spoon, and tighten the brake until you get a firm drag, NOT a lockup. Then loosen the starwheel one full turn, about 10 clicks. Don't worry if there's still a bit of drag, as the shoes will self-center the first time the brakes are applied. Just loosening enough to get free movement instead of a full turn will result in the brakes dragging as they heat up.
thanks guys this is the best site ever
