1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No, That little star wheel in your picture says it's a manual adjustment.
Not sure when self adjusting drum brakes came out, but I'm thinking a lot later than 63?
Grigg | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | And I bet the rear brakes are manual adjust as well,
Grigg | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The self-adjuster type will have a very fine-toothed star wheel and some linkage or a cable connecting it to the top of the brake at the anchor pin just above the wheel cylinder. It adjusts when the brakes are applied in reverse, but only when there's enough shoe movement to indicate the lining has worn.
To adjust that one, go through the slot behind the starwheel with a screwdriver or a brake spoon, and tighten the brake until you get a firm drag, NOT a lockup. Then loosen the starwheel one full turn, about 10 clicks. Don't worry if there's still a bit of drag, as the shoes will self-center the first time the brakes are applied. Just loosening enough to get free movement instead of a full turn will result in the brakes dragging as they heat up. Jerry
| | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | thanks guys this is the best site ever | | |
