5 members (klhansen, dt235sd, thekid1950, Hotrod Lincoln, RoadsScholar), 176 guests, and 1 robot.
Topics128,080
Posts1,056,064
Members48,433
Anybody build themselves a locker out of the stock 10 bolt rear... let's go 46' to 55' although up to 62' ought to be the same?
Jegs has a simple Powertrax conversion kit.
http://www.jegs.com/vs/Powertrax/754
Main thing need to know what number of splines the stock axels have?
Brett
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Those units are for the GM 10 bolt, not the earlier Eatons.
Steve
'49 3800
'52 3600
'57 3100
The stock axles are 17 spline. Early 12 bolts are also 17 spline, up to mid-'65. At this time, there are no locking/limited slip differentials available for the early rears.
Bill Burmeister
Thanks guys... did not need to get involved in that project anyway. I can keep my focus on my 2 current projects, steering and single lever shock rebuilds.
Back to the Engine Driveline section!
Thanks again,
Brett
cavebull
