BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
11 members (52Carl, Otto Skorzeny, Fifty-Five First, Danielbolt, Peggy M, Bill Hanlon, Waveski, Lightholder's Dad, hapydirty, Guitplayer, cspecken),
530
robot. | Key: Admin,
Mod | | Forums66 Topics126,781 Posts1,039,301 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jan 2002 Posts: 2,254 'Bolter | 'Bolter Joined: Jan 2002 Posts: 2,254 | At the last swap meet, out at the Ball Park in Arlington, I got a good deal on a bell housing. It was exactly like my old one, but without the crack in it. These things are heavy and, of course, I bought on the other side of the meet. Now that I have it cleaned it up and spray painted I notice it doesn't have the pin on the side for the shifter linkage. Poop. Back to square one. Is this from a truck with a hydromatic transmission? Can the the pin for the linkage be added? Or should I sell this one and look for another? Irwin. Did you ever get the one back from you buddy down at the train museum? Wanta trade?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | Joined: May 2001 Posts: 71 Wrench Fetcher | Wrench Fetcher Joined: May 2001 Posts: 71 | I went to the hardware store, bought some stock rod of the right diameter, cut a piece long enough to go into the housing and leave enough room for the linkage to mount, and glued it in with JB Weld. Seems to be fine. I hope it holds. Oh, you'll have to drill a hole through the rod at the far end to accommodate a cotter pin. | | |
#5107 01/16/2003 10:45 PM | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | oldbluetruck,
First, let me say that I do not know much about your year/series of truck (55 2nd, I assume).
In earlier HydraMatic trucks there was not a bell housing that was separate from the transmission assembly (thus, the manual transmission bell housing would not be of any use with a HydraMatic).
In manual transmission 216/235/261 trucks, if a factory 4-speed transmission was installed, there was no pivot pin sticking out because there was no need for a column-mounted linkage. Additional useless information: on some earlier 4-speeds there were also no holes on the upper steering column for the 3-speed shifter-bracket under the steering wheel.
As pknauth said, a stock or fabricated pin can be added.
Tim | | |
#5108 01/17/2003 12:40 AM | Joined: Mar 2002 Posts: 990 Member | Member Joined: Mar 2002 Posts: 990 | According to tclederman, you'll be out of luck on the bell housing from my old rust mountain because it had the 4 speed tranny. | | |
#5109 01/17/2003 12:47 AM | Joined: Aug 2001 Posts: 139 Member | Member Joined: Aug 2001 Posts: 139 | oldblue, could you drill and tap a hole for the pin? I think that woud be more secure than using JB Weld. Mike | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Sorry, I was not clear with my response. I think the 4-speed bell-housing had the hole but no pin - but I could easily be wrong.
irwin arnstein - on the driver's side of your 4-speed bell-housing is there a hole for the shift-linkage pivot pin? If not, then one would have to be drilled out (as suggested by slomoe).
Tim | | | | Joined: Mar 2002 Posts: 990 Member | Member Joined: Mar 2002 Posts: 990 | i don't have it here, but I can check if its still available. | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for all the info.
Tim, I never thought of the 4 speed. Irwin, if you wouldn't mind checking on the availability of your old bell housing, and if it has the hole or even the pin. I would really appreciate it.
As for mine. I do not have a drill press. It is one of the things I really want - but keep my eye in the classifieds to find a used one.
Does anyone know - if I get the hole drilled in my housing can the old pin be pulled out for use in the this new housing? And how to do it.
#5113 01/17/2003 10:20 PM | Joined: Mar 2002 Posts: 990 Member | Member Joined: Mar 2002 Posts: 990 | I got a drill press, I bet we can make it work. | | | | Joined: Aug 2000 Posts: 800 Shop Shark | Shop Shark Joined: Aug 2000 Posts: 800 | | | |
